Date/Time: Fri, 19 Apr 2024 05:35:40 +0000
Help with connection
View Count: 481
[2019-12-04 02:57:44] |
Lavorris WHITE - Posts: 12 |
can someone help me I just paid for package 5 and when I downloaded Sierra Charts it says not connected...any suggestions?
[2019-12-04 03:20:42] |
We want you to go through this Forced Login procedure here: Sierra Chart - Software Login Instructions: Forced Login Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
