Date/Time: Thu, 25 Apr 2024 17:12:34 +0000
Can subinstance use the market depth recorded by the main instance?
View Count: 527
[2019-12-03 22:58:48] |
User541156 - Posts: 67 |
To save disk space, Can a subinstance use the market depth recorded by the main instance?
[2019-12-04 04:16:11] |
Although a subinstance is getting the data from the primary application, each instance needs to have its own Market Depth files in order to avoid file conflicts between the instances.
