Date/Time: Sat, 20 Apr 2024 03:40:28 +0000
eod close not updating
View Count: 620
[2019-12-03 12:18:41] |
User875891 - Posts: 63 |
This has been a problem for a few weeks (since the sc update) cl eod does not update on my dom at close today it hasnt updated from fri close my dom shows a close of 55.17 as yesterdays close which I know to be incorrect as that was fri close reload and recalc did not help cqg data Date Time Of Last Edit: 2019-12-03 12:43:35
[2019-12-03 14:01:09] |
it just now reset
[2019-12-03 14:33:02] |
We are not understanding this. How do you observe: my dom shows a close of 55.17 as yesterdays close
on a Trading DOM?
[2019-12-03 14:44:32] |
yes the previous days close study all cl charts were effected not just dom reloaded each to no avail they reset at 1400 sc time |
[2019-12-03 17:56:51] |
Are you referring to the Previous Close Line study? And how do you have the Use Previous Close from Quote Data Input set? Here is the updated documentation for this study: Previous Close Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-12-03 18:07:54
[2019-12-03 18:49:08] |
yes to "previous close Line Study" previous close from quote data set to "yes" |
[2019-12-04 01:10:24] |
We recommend setting that Input to No because when it is Yes it is going to be very much data feed dependent which we have no control over because you are using the CQG data feed. Instead set the Session Times correctly within the chart. More information is here: Previous Close Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
