Date/Time: Thu, 25 Apr 2024 04:24:28 +0000
missing data contract month for PA (Palladium NYMEX) from 11/27/2017 to 2/26/2018
View Count: 571
[2019-12-03 01:21:28] |
User718576 - Posts: 2 |
There is a missing data contract month for PA (Palladium NYMEX) from 11/27/2017 to 2/26/2018 daily data. Can you please investigate?
[2019-12-03 03:57:26] |
First follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-12-03 15:04:15] |
I followed the instructions provided and yielded the same results. I see all contract months in the Multiple Symbol Selection Window with the missing month (PAH18) and select to delete all data and download. There is still a data gap between 11/27/2017 to 2/26/2018
[2019-12-04 04:15:21] |
We are definitely not seeing any problem with this at all: http://www.sierrachart.com/image.php?Image=1575432907833.png Two things: You are running an older version. Update: Software Download: Fast Update We will not provide support for an older version. 2. Re-download the data in the main instance first. We see you are using a sub instance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
