Date/Time: Sat, 20 Apr 2024 10:28:15 +0000
High Low Pullback Difference
View Count: 1100
[2019-12-02 21:18:40] |
User881696 - Posts: 16 |
Why is the BEST information from the Numbers Bars not accessible for simple alerts. I'm trying desperately to access SG37 and SG38 to create a Trading System Simple Alert. Can someone explain if this is possible or how to do it using ASCIL? Really HUGE thanks in advance...
[2019-12-03 00:11:28] |
What is the ID number of Numbers Bars Calculated Values on the chart and give us the Simple Alert formula that you are using.
[2019-12-05 00:28:08] |
I got it working. I had to dig through the forums and try various techniques, but I got it. Thanks....The Poc, IDx.SG42, I am trying to use this to see when the POC value is in a certain spot in a candle. I am not getting expected results. What I am trying to do: An Up Candle: I am looking for when the POC is below the open but above the Low / or POC is above the close but below the High A Down Candle: I am looking for when the POC is below the close but above the Low / or POC is above the open but below the High ... How can I achieve this? BIG thanks/// |
[2020-06-09 13:46:22] |
User769783 - Posts: 124 |
I have this coded already if you're interested
