Date/Time: Sat, 20 Apr 2024 05:18:12 +0000
[User Discussion] - New function proposal
View Count: 879
[2019-09-22 18:46:55] |
We recommend using ACSIL (Advanced Custom Study Interface and Language) and this particular functionality and develop a custom study to accomplish what you need: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-24 11:25:33] |
bradh - Posts: 853 |
I can help you with this ACSIL Study.
[2019-09-24 14:12:54] |
JG83 - Posts: 10 |
This is a great idea! I use a secondary program for market events, although noting the events on the chart is very efficient. If this code gets generated please add me to the short list. Some recommendations I have; 1. Color coding zoned areas in order of market importance, Low/Moderate/High designations. 2. Market event text noted on chart area as their can be many in a day. 3. Optional zone translucent % fill color. |
[2019-09-25 11:55:03] |
Gyorgy, I sent you a direct message request. Let's continue this conversation off line. BradH |
[2019-09-25 12:10:54] |
Hi Gyorgy, I got your direct message. You need to give me permission to contact you by Direct Message too, so I can respond. Brad |
