Date/Time: Thu, 27 Feb 2025 19:34:15 +0000
How to drag the chart when at Crosshair mode?
View Count: 1024
[2019-09-08 08:28:17] |
User392279 - Posts: 67 |
Hi, is there a way to do that?
[2019-09-09 16:33:07] |
John - SC Support - Posts: 38246 |
Yes, just set the option under Global Settings >> Tool Settings >> Chart Values to either Always On When Using other Tools or Always Enabled when Using Other Tools. Refer to the information for this setting within this section of the documentation: Chart Drawing Tools: Chart Values Tool Configuration And then you will be able to see the crosshairs and Tools Value Window when using other tools, including the Hand tool, which allows you to drag the chart. Refer to the following for the Hand tool: Chart Drawing Tools: Hand For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-27 16:56:05] |
User702249 - Posts: 1 |
but that doesn't work why?
[2021-07-27 17:02:29] |
What exactly is not working for you? What is the state of the various settings and the selections you are making that is not working and how do you expect it to be working?
