Date/Time: Fri, 27 Sep 2024 03:46:51 +0000
[Programming Help] - Alert Condition
View Count: 585
[2019-04-09 12:52:07] |
User796685 - Posts: 1 |
I am trying to create an alert condition that signals whenever the "Delta Momentum" indicator pushes up or down 3 times and then crosses through zero. For example, if we have a green push, a green push, a green push, then a red push I want the signal to trigger, but if it pushed more then 3 times or less then 3 times I do not want it to trigger. Same exact thing for three red pushes then a green push. I have attached a screen shot to provide a visual of the delta momentum pushes (I have circled the examples in aqua color).
Private File |
