Date/Time: Fri, 27 Sep 2024 03:45:24 +0000
[Programming Help] - Does anyone have working example(code) of volume profile using ACSIL?
View Count: 1745
[2019-04-09 09:13:37] |
User353585 - Posts: 66 |
Hello, I'm looking for a working example of volume profile using ACSIL. I might be able to retrieve data from the chart using sc.VolumeAtPriceBars, but I have no idea how should I display it since I'm not a programmer. or is there any way to modify VbP study data that's already on the chart? It would be greatly appreciated if someone can share a example. thanks. Date Time Of Last Edit: 2019-04-09 09:15:54
[2019-04-09 09:27:55] |
This really is not simple. There is not a straightforward/simple way to do this in ACSIL which will be like how Sierra Chart does volume profiles. Doing this in ACSIL is quite involved.
[2019-04-09 11:40:10] |
ganz - Posts: 1048 |
User353585 ... to draw vPOC, VAH, VAL for Tools->Rectangle area that was selected by you. sc.ReadIntradayFileRecordForBarIndexAndSubIndex() Date Time Of Last Edit: 2019-04-09 11:44:27
