Date/Time: Tue, 23 Apr 2024 07:53:46 +0000
Trade Activity Log - P/L Format Ticks - Commission
View Count: 596
[2019-03-21 02:37:15] |
User796776 - Posts: 95 |
The Commission column displays integer values when using the P/L Format Ticks(T). Would it be possible to display a decimal value in the commission field when using Ticks as the P/L Format? For example using the ES: Quantity * Commission / Tick size 1*5/12.5=0.4 but a 0 commission is shown 2*5/12.5=0.8 but a 1 commission is shown 3*5/12.5=1.2 but a 1 commission is shown When saving the log the commissions are also written as integers. |
[2019-03-26 19:57:23] |
Is this working as designed or a bug?
