Date/Time: Thu, 27 Feb 2025 00:15:56 +0000
[Programming Help] - Numbers bar calculated values - Avg bid\ask volume per price
View Count: 1865
[2018-11-28 14:49:48] |
User150852 - Posts: 38 |
You provide 'Average volume per price' but I would like to see these Avgs for bid\ask volumes. Is there a way to show them? |
[2018-11-28 19:44:10] |
John - SC Support - Posts: 38222 |
Which do you want to see - the Average Bid/Ask Volume per Price, or the Average Bid/Ask Non-Zero Volumes? For example, if the Bid Volumes for a bar are 0, 5, 10, 0, 15 then the Average Bid/Ask Volume per Price would be 6 (30/5), but if you weren't interested in the zero volumes and wanted to know the average of the non-zero bids, you would get 10 (30/3). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-28 21:57:02] |
We have gone ahead and implemented Average Non-Zero Ask Volume and Average Non-Zero Bid Volume in the Numbers Bars Calculated Values 2 study. This will be available in the next Pre-Release (1848). If you do need the Average Ask/Bid Volume per Price, let us know and we will look into adding it. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-29 07:50:52] |
Yes, I need the average volume per price as it shows the 'REAL' average volume that takes the price to move a tick up and down in the current auction. Also, i think it should work on the pullback column as well Date Time Of Last Edit: 2018-11-29 08:44:31
[2019-02-27 17:23:34] |
whats1thingnow - Posts: 407 |
Average Bid/Ask Volume per Price [...]
For example, if the Bid Volumes for a bar are 0, 5, 10, 0, 15 then the Average Bid/Ask Volume per Price would be 6 (30/5) Yes, I need the average volume per price as it shows the 'REAL' average volume that takes the price to move a tick up and down in the current auction.
yes, exactly what i was looking for! +1 |
[2021-06-10 05:49:00] |
Mark_47 - Posts: 27 |
Hello, I am looking for the BID/ASK average volume per Price, including zeros in the calculation (0, 5, 10, 0, 15 --> (30/5) --> 6). Can I find it somewhere? Thank you. |
