Date/Time: Sat, 23 Nov 2024 22:03:53 +0000
Footprint Chart
View Count: 1454
[2018-11-12 14:11:50]
Jeffrey S - Posts: 42
Is there a way to see the executed bid and ask separate on the footprint?
[2018-11-12 18:35:41]
We do not understand this. To whatever extent this is supported would be controlled through this setting:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#TextTypes
It sounds like you are referring to: Bid Vol x Ask Vol
Date Time Of Last Edit: 2018-11-12 18:36:28
[2018-11-12 19:21:06]
Its very hard to read the numbers on this setting. How can I see the numbers easier?
[2018-11-12 19:58:00]
Why do you say that?
Provide an image of the chart or Trade DOM, by following these instructions:
[2018-11-12 20:06:18]
http://www.sierrachart.com/image.php?Image=1542053118363.png
[2018-11-12 20:09:11]
Please confirm that it is only showing the bids and asks that are actually being executed. Thanks for all of your help.
[2018-11-12 20:18:00]
Refer to this particular documentation for scaling a Numbers Bars chart:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#ScalingANumbersBarsChart
Yes this is the case.
