Date/Time: Sat, 23 Nov 2024 16:05:26 +0000
Failed setup
View Count: 929
[2018-08-21 19:16:37] |
Jacqui Rector - Posts: 8 |
Hi, I'm struggling to set up my account. My goal is to have access/view NYSE internals like the Tick and Advance decline. In the process of setting up attached is what I encountered. What am I missing? Thanks. Jacqui |
Set up failed.JPG / V - Attached On 2018-08-21 19:15:48 UTC - Size: 169.16 KB - 319 views |
[2018-08-21 19:38:06] |
You do not need to use the Sierra Chart Exchange Data Feed for this data. Instead refer to this page: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-21 20:40:20] |
The option I'm required to choose is not available. Global Settings >> Data/Trade Service Settings >> Service to SC Market Stats (statistics). What do I do? |
[2018-08-21 20:49:37] |
We need to update the documentation. Set the Global Settings >> Data/Trade Service Settings >> Service to "SC Data- All Services".
[2018-08-21 23:02:41] |
I selected "SC Data - All Services" from then on I could not figure what next the only option I have under Service Setting is "Intraday Download Interval fot Non-Real-time Symbols (min)" after selecting SC Data - All Services. I would really like to be set up so I can use your system in my trading tomorrow. What number do I call to get help with setting up? Thanks! |
[2018-08-22 00:15:36] |
The market statistics symbols are listed in File >> Find Symbol >> Market Stats. Here are detailed instructions to open a chart: Getting Started, Opening Charts and Basic Trading: Open A Chart Are these the only symbols you need access to?: My goal is to have access/view NYSE internals like the Tick and Advance decline.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-22 01:22:18
[2018-08-22 01:05:19] |
Thank you!
[2018-08-22 02:29:57] |
Sorry I missed your earlier question about symbols I need to access. I need to access all Futures Symbols. Thank you |
[2018-08-22 02:44:35] |
Do you need real-time data for futures? What futures trading/brokerage service do you use? For the reason why we ask this question, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#UnderstandingAccessingDataFromCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-22 02:56:54] |
Yes I need real-time data for futures
[2018-08-22 05:28:23] |
[2018-08-22 16:02:38] |
I'm using Charles Schwab for trading.
[2018-08-22 17:23:16] |
Refer to this page and read it in its entirety: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above, completely before you ask further questions about real-time futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
