Date/Time: Thu, 25 Apr 2024 09:09:36 +0000
[Programming Help] - sc.DateTimeOut[] always returns 30.12.1899
View Count: 887
[2018-05-09 16:20:34] |
BrMa - Posts: 77 |
Dear ladies and gentlemen, I'm trying to get the SCDateTime-element for a specific bar when it was finished. The documentation says (http://www.sierrachart.com/index.php?page=doc/ACS_ArraysAndLooping.html#ArrayIndexing) that sc.DateTimeOut[] would be the right array to look at. Unfortunately sc.DateTimeOut[] returns 30.12.1899 00:00:00 (which is equal to a zero-value of the variable) regardless which index I'm passing.However - if I'm using sc.BaseDateTimeIn[] , it returns the right begin-SCDateTime for the bar.Can you give me a hint what I'm doing wrong that sc.BaseDateTimeIn[] works and sc.DateTimeOut[] not, using the same index?I'm also passing you my debug-routine to check the values - maybe it helps to determine the failure: if (debug)
{ char t_output[254]; int Year, Month, Day, Hour, Minute, Second; DATETIME_TO_YMDHMS(sc.DateTimeOut[sc.IndexOfLastVisibleBar - 1], Year, Month, Day, Hour, Minute, Second); sprintf(t_output, "*** DateTimeOut: %d.%d.%d %d:%d:%d ***", Day, Month, Year, Hour, Minute, Second); sc.AddMessageToLog(t_output, 1); DATETIME_TO_YMDHMS(sc.BaseDateTimeIn[sc.IndexOfLastVisibleBar - 1], Year, Month, Day, Hour, Minute, Second); sprintf(t_output, "*** BaseDateTimeIn: %d.%d.%d %d:%d:%d ***", Day, Month, Year, Hour, Minute, Second); sc.AddMessageToLog(t_output, 1); } |
[2018-05-09 19:02:31] |
No, that is definitely not the right array to use. You need to use: http://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Variables_And_Arrays.html#scBaseDateTimeIn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-11-29 14:37:26] |
scotteza - Posts: 4 |
I was just reading the documentation for "Working with ACSIL Arrays and Understanding Looping" (Working with ACSIL Arrays and Understanding Looping). I understand what sc.BaseDateTimeIn[] is used for (holding the start times of price data bars). But I don't understand what sc.DateTimeOut is supposed to be used for. What data does this array hold? Thanks in advance! |
[2019-11-29 21:46:30] |
Did you read the documentation for this?
[2019-12-03 12:52:29] |
I had only read the info on the page Working with ACSIL Arrays and Understanding Looping. Posting for anyone else who comes across this post and wonders the same thing I did: I just realised that there is more extensive documentation on these array at ACSIL Interface Members - Variables and Arrays: sc.DateTimeOut[], and I found my answer there. |
