DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 15:12:35 +0000
Google Protocol buf message header
View Count: 4387
[2018-04-14 19:46:15]
enemyspy - Posts: 306
According to the documentation here: https://www.dtcprotocol.org/#GoogleProtocolBuffers
each outgoing message needs the s_DTCMessageHeader struct prepend .
I noticed that the above struct is not in the DTCPrococol.proto file found here : http://dtcprotocol.org/DTC_Files/DTCProtocol.proto
The doc string indicates that it should be prepended by a little endian binary:
What is the best solution:
-add the struct to the .proto and recompile?
-prepend a non protobuf binary struct? Does the header need to a have null terminating seperator?
Date Time Of Last Edit: 2018-04-14 19:47:02
[2018-04-14 22:08:56]
ok sweet finally it working. this should be pretty easy now.
Has anyone posted any benchmarking results detailing the performance difference between binary and the google buffers. I read they can be particularly slow for python.
[2018-04-20 08:01:01]
DTC Engineering - Posts: 320
Yes. It is fully independent of the protocol buffer encoding and decoding.
No.
This is a good question. Certainly Binary Encoding with Variable Length Strings is going to be the ultimate encoding.
We think using the Google protocol buffer version 3 compiler and library, which is also compatible with version 2 protocol files, and being the DTC Protocol use of Google protocol buffers is straightforward, that it should be quite efficient.
Date Time Of Last Edit: 2018-04-20 08:05:51
