Date/Time: Sat, 23 Nov 2024 16:31:20 +0000
Historical Stock Data Integration
View Count: 759
[2017-12-07 17:21:48] |
User511364 - Posts: 7 |
I have opened an account with Infinity Futures (a service by Transact Futures) but it does not include historical intraday data for the NYSE and other stock exchanges. I'd like to integrate your historical data downloads with the version of Sierra Chart Infinity supports so I can use the same platform for analysis of both my stock and option trades, which are handled by Schwab, and my futures trades, which are handled by Infinity Futures/Transact. I know it's possible to run two instances of Sierra Chart side-by-side, but using SC's historical data feed in the same instance of Sierra Chart as Infinity would be less cumbersome for me to use. Naturally, I would maintain a Standard Service Package 3 account to pay for the service. Any advice or pointers you can give for setting up this configuration would be appreciated. Date Time Of Last Edit: 2017-12-07 18:08:48
[2017-12-07 19:04:16] |
You just need to use your installation of Sierra Chart which is separate from the Sierra Chart provided by Infinity and use your own Sierra Chart account when logging into that. To configure that installation to work with TransAct, follow the set up instructions here: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions In that instance set Global Settings >> Data/Trade Service Settings >> SC Server Settings >> UDP Port to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-07 19:05:27
