Date/Time: Thu, 27 Feb 2025 00:30:19 +0000
Percentage change chart for multiple symbols...
View Count: 2222
[2017-10-08 20:29:47]
User629089 - Posts: 93
I can't figure out how to have a percentage change chart with multiple symbols. Using a line on close chart and adding the "Overlay (Single Line)" studies will get add'l symbols on a chart but the chart is based on the main symbol's price set up through chart settings. Using the "Percent Change Since Previous Close" study will show the percent change of the main symbol but again I can't figure out how to add add'l symbols for this. Is this possible?
Thanks...
[2017-10-09 18:56:25]
We are going to change the Percent Change Since Open study in the next release to support the new Percent Value Format that Sierra Chart has.
What you will want to do is apply the "Percent Change Since Open" study to each individual chart for the symbols you want to do this for.
And then overlay the Percent Change Since Open studies to a common chart using this study:
Study/Price Overlay Study
In the next release, we will add support for Percent Change Since Open to be based on other studies like the Overlay (Single Line) study so you can accomplish this in the way that you originally were trying.
We know you made reference to Percent Change Since Previous Close, we will do the same updates to that study as well.
Date Time Of Last Edit: 2017-10-09 18:59:17
[2021-06-14 12:29:06]
User90125 - Posts: 715
+1
