Date/Time: Sat, 23 Nov 2024 16:25:53 +0000
delete chartbooks
View Count: 2776
[2017-10-03 23:05:57] |
madra - Posts: 109 |
Hello, I have followed the process in documentation for deleting chartbooks. I have have done this several times without success. There are two chartbooks (carter and ema) that i want to remove because the studies are no longer in these chartbooks just a blank screen. Other chartbooks are fine do not know why the studies from these chartbooks disappeared. Thank you |
[2017-10-04 04:58:26] |
Here are the instructions to delete a Chartbook: Chartbooks (Workspaces): Deleting a Chartbook Make sure the Chartbooks are closed before you delete them. Close them first with File >> Close All Chartbooks. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-16 15:53:23] |
User743518 - Posts: 1 |
I followed all instructions on deleating a chartbook and they dissapear untill I turn the machine on again t he next day they are not deleated and come back...how to get rid of permanetly |
[2024-08-16 18:22:47] |
Sierra_Chart Engineering - Posts: 17150 |
Check this page: https://www.sierrachart.com/UserControlPanel.php?page=EnabledCustomStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
