Date/Time: Fri, 27 Sep 2024 03:56:45 +0000
Histogram bars
View Count: 1857
[2017-09-20 11:46:53] |
User780238 - Posts: 45 |
Is there a way to attach an outer line to the histogram bars to smooth out the look. I see it on another charting program and for my purposes, it’s easier to read. Thanks, |
[2017-09-20 20:41:28] |
We will prepare documentation for how to do this.
[2017-09-20 20:52:08] |
Thanks any idea as to when this will be available?
[2017-09-21 05:02:50] |
We will have this done by the end of the week.
[2019-04-08 13:46:22] |
DevTrader79 - Posts: 44 |
Could you please guide me how to draw the outer line of the histogram bars.
[2019-04-08 20:05:09] |
We are not sure what histogram bars you are referring to, but here are couple of things that you may be referring to. Refer to the following for adding a line to bars: Chart Studies: Displaying a Study with Both Bars and Bounding Line Refer to the following for how to display the outer line of a Volume by Profile Graph (Hologram): Volume By Price Study: Volume Bars Draw Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-09 13:38:18] |
Thanks. It worked for me. I was trying to draw outer line on 3/10 oscillator histogram bars. I hope Duplicating two heavy studies will not slow down the chart performance.
