Date/Time: Sat, 23 Nov 2024 23:25:23 +0000
Code errors
View Count: 2669
[2013-09-05 15:47:52]
user6275 - Posts: 13
Compiled yesterday worked fine now I get all of these error references that dont match anything in my code? Any ideas?
Error MEssage:
In file included from C:\SierraChart\ACS_Source\sierrachart.h:155:0,
from C:\SierraChart\ACS_Source\Uber.cpp:13:
C:\SierraChart\ACS_Source\scdatetime.h: In function 'SCDateTime GetCurrentDateTimeInGMT()':
C:\SierraChart\ACS_Source\scdatetime.h:1180:2: error: 'SYSTEMTIME' was not declared in this scope
SYSTEMTIME st;
C:\SierraChart\ACS_Source\scdatetime.h:1180:13: error: expected ';' before 'st'
SYSTEMTIME st;
C:\SierraChart\ACS_Source\scdatetime.h:1183:2: error: '::GetSystemTime' has not been declared
::GetSystemTime(&st);
C:\SierraChart\ACS_Source\scdatetime.h:1183:19: error: 'st' was not declared in this scope
In file included from C:\SierraChart\ACS_Source\Uber.cpp:13:0:
C:\SierraChart\ACS_Source\sierrachart.h: At global scope:
C:\SierraChart\ACS_Source\sierrachart.h:182:45: warning: '__cdecl__' attribute only applies to function types [-Wattributes]
typedef void (SCDLLCALL* fp_ACSGDIFunction)(HWND WindowHandle, HDC DeviceContext);
C:\SierraChart\ACS_Source\sierrachart.h:182:45: error: typedef 'fp_ACSGDIFunction' is initialized (use decltype instead)
C:\SierraChart\ACS_Source\sierrachart.h:182:45: error: 'HWND' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:182:64: error: 'HDC' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h: In static member function 'static char* SCString::StringNew(size_t)':
C:\SierraChart\ACS_Source\sierrachart.h:815:46: error: 'GetProcessHeap' was not declared in this scope
p_Block = (char*)HeapAlloc(GetProcessHeap(), 0, (SIZE_T)NumBytes);
C:\SierraChart\ACS_Source\sierrachart.h:815:53: error: 'SIZE_T' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:815:68: error: 'HeapAlloc' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h: In static member function 'static void SCString::StringDelete(char*)':
C:\SierraChart\ACS_Source\sierrachart.h:823:29: error: 'GetProcessHeap' was not declared in this scope
HeapFree(GetProcessHeap(), 0, String);
C:\SierraChart\ACS_Source\sierrachart.h:823:41: error: 'HeapFree' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:882:3: error: 'COLORREF' does not name a type
COLORREF Color;
C:\SierraChart\ACS_Source\sierrachart.h:909:3: error: 'COLORREF' does not name a type
COLORREF SecondaryColor; // For Highlight tools
C:\SierraChart\ACS_Source\sierrachart.h:922:3: error: 'COLORREF' does not name a type
COLORREF LevelColor[SC_DRAWING_MAX_LEVELS];
C:\SierraChart\ACS_Source\sierrachart.h: In member function 'void s_UseTool::Clear()':
C:\SierraChart\ACS_Source\sierrachart.h:993:4: error: 'Color' was not declared in this scope
Color = 0xff000000;
C:\SierraChart\ACS_Source\sierrachart.h:1001:4: error: 'SecondaryColor' was not declared in this scope
SecondaryColor = 0xff000000;
C:\SierraChart\ACS_Source\sierrachart.h:1009:5: error: 'LevelColor' was not declared in this scope
LevelColor = 0xff000000;
C:\SierraChart\ACS_Source\sierrachart.h: In member function 'long unsigned int s_SCInput_145::GetColor() const':
C:\SierraChart\ACS_Source\sierrachart.h:2482:48: error: 'RGB' was not declared in this scope
return (BooleanValue != 0) ? RGB(255,255,255) : 0;
C:\SierraChart\ACS_Source\sierrachart.h: In member function 's_SCInput_145& s_SCInput_145::SetColor(unsigned char, unsigned char, unsigned char)':
C:\SierraChart\ACS_Source\sierrachart.h:2792:39: error: 'RGB' was not declared in this scope
return SetColor(RGB(Red, Green, Blue));
C:\SierraChart\ACS_Source\sierrachart.h: In member function 's_SCInput_145& s_SCInput_145::SetString(const char*)':
C:\SierraChart\ACS_Source\sierrachart.h:2873:28: error: 'GetProcessHeap' was not declared in this scope
HeapFree(GetProcessHeap(), 0, (char*)StringValue);
C:\SierraChart\ACS_Source\sierrachart.h:2873:52: error: 'HeapFree' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:2885:55: error: 'GetProcessHeap' was not declared in this scope
char* NewString = (char*)HeapAlloc(GetProcessHeap(), 8 /*HEAP_ZERO_MEMORY*/, NumBytes);
C:\SierraChart\ACS_Source\sierrachart.h:2885:90: error: 'HeapAlloc' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:2986:2: error: 'COLORREF' does not name a type
COLORREF TextBackgroundColor;
C:\SierraChart\ACS_Source\sierrachart.h: In constructor 's_NumericInformationGraphDrawTypeConfig::s_NumericInformationGraphDrawTypeConfig()':
C:\SierraChart\ACS_Source\sierrachart.h:2999:3: error: 'TextBackgroundColor' was not declared in this scope
TextBackgroundColor = COLOR_BLACK;
In file included from C:\SierraChart\ACS_Source\sierrachart.h:157:0,
C:\SierraChart\ACS_Source\sccolors.h:16:30: error: 'RGB' was not declared in this scope
#define COLOR_BLACK RGB(0,0,0)
C:\SierraChart\ACS_Source\sierrachart.h:2999:25: note: in expansion of macro 'COLOR_BLACK'
C:\SierraChart\ACS_Source\sierrachart.h:4518:2: error: 'COLORREF' does not name a type
COLORREF RGBInterpolate(const COLORREF& Color1, const COLORREF& Color2, float ColorDistance)
C:\SierraChart\ACS_Source\sierrachart.h:4669:2: error: 'HWND' does not name a type
HWND ChartWindowHandle;
C:\SierraChart\ACS_Source\sierrachart.h:5701:66: error: 'COLORREF' has not been declared
unsigned long (SCDLLCALL* CombinedForegroundBackgroundColorRef)(COLORREF ForegroundColor, COLORREF BackgroundColor);
C:\SierraChart\ACS_Source\sierrachart.h:5701:92: error: 'COLORREF' has not been declared
C:\SierraChart\ACS_Source\sierrachart.h:5753:2: error: 'fp_ACSGDIFunction' does not name a type
fp_ACSGDIFunction p_GDIFunction;
C:\SierraChart\ACS_Source\Uber.cpp: In function 'void scsf_UberOn(SCStudyInterfaceRef)':
C:\SierraChart\ACS_Source\Uber.cpp:149:48: error: 'RGB' was not declared in this scope
BuyEntrySubgraph.PrimaryColor = RGB(0, 255, 0);
C:\SierraChart\ACS_Source\Uber.cpp: In function 'void scsf_UberOff(SCStudyInterfaceRef)':
C:\SierraChart\ACS_Source\Uber.cpp:841:48: error: 'RGB' was not declared in this scope
[2013-09-05 15:49:05]
Oh yeah, Now ALL of my custom studies code give the exact same errors, what changed? I have to recode 8 studies now.
[2013-09-05 16:03:38]
This problem was resolved. What version of Sierra Chart are you running?
