Date/Time: Sat, 23 Nov 2024 23:33:40 +0000
Remove Overnight Gaps
View Count: 2026
[2013-09-04 18:15:26] |
JohnnyT__ - Posts: 16 |
Hi I compare often my charts with other software (Free Stock Charts)that does not have the overnight session calculated and my intraday charts are very far from them, the historical charts are similar (daily, weekly)but not the intraday cahrts. is it possible to remove the overnight gap on the intraday charts so that i get a similar chart? In my charts the first candle of the session is completely diferent where in the other charts theres a candle that atends to the close of the previous session i wont get that in sierra. I use SPX500 with the SC Forex Data, and put the session times: start time (09:29:59h)and End Time (15:59:59h... tried other session times with no luck Am i doing something wrong? Thanks in advance |
[2013-09-04 18:27:37] |
This is not really clear for us. You can set the Session Times to whatever you require. If you want the full 24 hours, then set them to display the full 24 hours.
