Date/Time: Sat, 23 Nov 2024 23:36:07 +0000
CAC40 Futures - Monep: download error
View Count: 1746
[2013-09-04 16:28:14] |
fsovir - Posts: 14 |
Hello, The CAC40 futures do no more display correctly since last monday. This seems to be due to Interactive Broker file format change. A new symbol (MFCU3 september 2013, with 1 multiplier) has appeared and is not taken into account by Sierra Chart. Furthermore, it seems to affect other symbols (FCEU3 september 2013). FCEU3 symbol IB future CAC40 6EU3 new symbol Thank you for your help, regards, So |
[2013-09-04 17:59:21] |
Use this symbol: CAC40-201309-MONEP-EUR-10 You will also see this new symbol listed under File >> Find Symbol after a restart. The old one can be manually deleted through Global Settings >> Symbol Settings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-04 17:59:39
[2013-09-04 19:02:24] |
Thank you Works ok Regards So |
