Date/Time: Sat, 23 Nov 2024 23:35:24 +0000
quoteboard question
View Count: 1545
[2013-09-04 14:35:59] |
User22396 - Posts: 191 |
is there a way to make the quoteboard part of the chartbook so it will tile like a chart? |
[2013-09-04 18:11:54] |
No, this is not supported. It is far too complicated to support that.
[2013-09-04 19:09:18] |
ok so no tiling but is there a way to keep the quoteboard within the chartbook? attach /detach doesnt seem to do anything
Date Time Of Last Edit: 2013-09-04 19:09:39
