Date/Time: Sat, 23 Nov 2024 23:30:53 +0000
Data Issue
View Count: 1609
[2013-09-03 23:40:35] |
C. Notes - Posts: 129 |
Hi, I have been using the IB feed for FX....and while IB does have some advantages for FX, the data is to say the least horrible... Not to mention other oddities that I still can't pinpoint...likely emanating from the clunky trader workstation. Is there any way to trade off of the Sierra feed? I seem to remember a Kiwi post along these lines I just couldn't find it... Some pairs i'm stuck with 2-3 days backfill max..Not even long enough to get a weekly pivot up.. Cheers... |
[2013-09-04 03:18:12] |
Yes. Refer to the instructions here: https://www.sierrachart.com/index.php?l=doc/MultipleServices.html You will want to use the data from the Sierra Chart real-time and Historical Forex Data service: https://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-04 03:18:30
[2013-09-04 04:01:57] |
Oh wow... This is super super terrific... Do you recommend using your server or the FXCM fix? Great job...this has really come quite a ways... |
[2013-09-04 04:16:25] |
Use our server for sure.
[2013-09-04 04:53:14] |
Gotcha... Running like a dream...Now if I could just prevent the TWS from shutting down at 10PM!... lol |
