Date/Time: Sat, 23 Nov 2024 23:33:45 +0000
Cumulative Delta Volume Bars
View Count: 1894
[2013-09-03 20:43:06]
kleros - Posts: 21
I have installed Sierra Chart on my PC and Macbook (using Parallels). I am using OEC for my data provider. The cumulative delta bars (volume) and the shape the 7500 volume candlesticks do not look the same on each version For instance, on my PC the cumulative delta for 9/3/13 closed the pit session (1:15pm Pacific) at -1620. On my Mac, the cumulative delta was -7784. Both versions have the cumulative delta indicator set to "reset at start of trading day." The data/trade service settings for both installs are the same. I am also using the Sierra Chart Historical Data Service. Can you help with this issue?
Chris
[2013-09-04 04:50:58]
Refer to this page for instructions:
https://www.sierrachart.com/index.php?l=doc/helpdetails47.html
