Date/Time: Sat, 23 Nov 2024 23:48:14 +0000
Support Board Connection
View Count: 1357
[2013-09-02 05:06:57] |
User123496 - Posts: 27 |
I think something is wrong with my connection to the Support Board from the Help button in AT Charts. When I click on it I always get a message that I am not connected to a Support Board and have to find the login somewhere else. Please advise. Thank you
[2013-09-02 05:32:04] |
This is true. There is no way to directly login from AT Charts to the support board. You have to manually login.
