Date/Time: Sat, 23 Nov 2024 23:43:08 +0000
sim trade data does not clear
View Count: 1958
[2013-08-31 13:41:45] |
joer - Posts: 41 |
When starting a backtest, a pop up box asks if I want to clear the sim trade data. It used to clear the data if I replied yes, but it no longer does that. I have to manually select the clear data option from the trade menu to clear the data. Why does it no longer clear in response to the prompt when starting a backtest?
[2013-08-31 22:56:13] |
Checking on this now.
[2013-08-31 23:17:54] |
We have tested this and we do not see a problem. One thing to be aware of is there are two different sources of trade simulation data. One for Replays and one for Simulated trading that occurs outside of replays. When starting a replay only the trade related data for the replay is cleared. For more information, see this section here: http://www.sierrachart.com/index.php?l=doc/doc_TradeMenu.html#SimulationFillsSource Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
