Date/Time: Sat, 23 Nov 2024 23:52:47 +0000
Moving Chart Vertically
View Count: 3001
[2013-08-30 10:24:58]
Demi1201 - Posts: 68
I would like to be able to blow up a chart in vertical scale and then adjust the display so that the area I'm interested in is visible. This would require moving the chart up and down in some way, which I can't find. Hand tool doesn't work.
Is this possible?
[2013-08-30 12:31:30]
Sawtooth - Posts: 4118
The Hand tool will do this.
Go to Global Settings >> Tool Settings > General tab
-set 'After Single Tool Use Change To:' to Hand
-Check 'Support Vertical Scaling/Movement With Hand Tool'
[2013-08-31 11:26:19]
This is possible using Interactive Scale Move:
http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling
