Date/Time: Sat, 23 Nov 2024 23:18:46 +0000
Integer types in GSP
View Count: 1440
[2013-08-30 07:20:27]
vbmithr - Posts: 204
Reading the header file of GSP, I see that a lot of fields have type int. int does not have a standard size across architectures. IsĀ 32 bits enough to hold data that can be put in a "int" ?
Cheers, and thanks,
Vincent
[2013-08-30 09:46:49]
In GSP an integer is 32 bits. In the way that integers are used in GSP, 32 bits is plenty of capacity. Where 64 bits are necessary, we would clearly specify a 64-bit integer. In most places in GSP, the UNIX timestamps are 64 bits.
We will make it clear in the GSP header file, that the integers are 32 bits.
