Date/Time: Sat, 23 Nov 2024 23:49:28 +0000
installing a .cpp
View Count: 2386
[2013-08-29 15:26:50] |
pismo10 - Posts: 159 |
I downloaded a .cpp that I want to install and use. How? Thanks |
[2013-08-29 16:37:59] |
Refer to the instructions here: https://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-30 13:27:00] |
Wow..Could this be any more complicated..
[2013-08-30 18:43:56] |
As you go through the steps, you will actually see that it is quite simple. The documentation is thorough to cover all possibilities and to provide complete information.
[2013-08-31 14:49:11] |
So i get this raft of errors. Thoughts? Thanks C:\SierraChart\ACS_Source\sierrachart.h: At global scope: C:\SierraChart\ACS_Source\sierrachart.h:2986:2: error: 'COLORREF' does not name a type C:\SierraChart\ACS_Source\sierrachart.h: In constructor 's_NumericInformationGraphDrawTypeConfig::s_NumericInformationGraphDrawTypeConfig()': C:\SierraChart\ACS_Source\sierrachart.h:2999:3: error: 'TextBackgroundColor' was not declared in this scope C:\SierraChart\ACS_Source\sierrachart.h:2999:25: error: 'RGB' was not declared in this scope C:\SierraChart\ACS_Source\sierrachart.h: At global scope: C:\SierraChart\ACS_Source\sierrachart.h:4518:2: error: 'COLORREF' does not name a type C:\SierraChart\ACS_Source\sierrachart.h:4669:2: error: 'HWND' does not name a type C:\SierraChart\ACS_Source\sierrachart.h:5701:66: error: 'COLORREF' has not been declared C:\SierraChart\ACS_Source\sierrachart.h:5701:92: error: 'COLORREF' has not been declared C:\SierraChart\ACS_Source\sierrachart.h:5753:2: error: 'fp_ACSGDIFunction' does not name a type C:\SierraChart\ACS_Source\HighVAP.cpp: In function 'void scsf_HighVAP(SCStudyInterfaceRef)': C:\SierraChart\ACS_Source\HighVAP.cpp:31:29: error: 'RGB' was not declared in this scope -- End of Build -- 10:47:23 |
[2013-08-31 21:11:25] |
This has been resolved. Update Sierra Chart to the latest version by selecting Help >> Download Prerelease.
