Date/Time: Sat, 23 Nov 2024 23:32:08 +0000
Zigzag not displaying Length accurately
View Count: 1563
[2013-08-29 14:54:58] |
George - Posts: 60 |
The new Zigzag study is not displaying the Length of the of each wave accurately. It is rounding off each Length to the whole number and not including anything to the right of the decimal point, except zeros. The attached image showing just the Reversal Price and Length shows the problem. Thanks in advance. http://www.sierrachart.com/image.php?l=1377788245636.png Edit: The new ZZ code states: ZigzagLineLength = abs(ZigZagLine[Index] - ZigZagLine[BackRefIndex]); The old ZZ code states: ZigzagLineLength = ZigZagLine[Index] - ZigZagLine[BackRefIndex]; I changed the new ZZ study ZigzagLineLength, to the old and everything works right now. Date Time Of Last Edit: 2013-08-29 16:24:47
[2013-08-30 05:53:29] |
Thank you. We will look this over.
[2013-08-30 13:10:25] |
Al SC Developer - Posts: 434 |
This will be resolved in ver 1019.
