Date/Time: Sat, 23 Nov 2024 23:27:30 +0000
ESM3 Data from 3/8 onward
View Count: 1517
[2013-08-29 12:30:52] |
infpz - Posts: 826 |
Hello, Trying to bring up a 5 minute chart of ESM3 data from 3/8 onward. I can only get as far back as about 4/22. I have days to load set to 180. I don't mind longer load times, but I would like to see this data. Thanks, Patrick |
[2013-08-29 16:29:28] |
Refer to help topic 42.1 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails42.html For that symbol the data goes back to March 3. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-29 17:32:30] |
This was resolved. Thanks.
