Date/Time: Sat, 23 Nov 2024 23:39:50 +0000
SC VERSION 1016 : PROBLEM ACESS LOGIN
View Count: 1539
[2013-08-29 06:15:46]
salsem - Posts: 43
Hello SC support ,
this morning I was denied access login
I ask the help of the support SC
thanks in advance
imagesc 1016.jpg / V - Attached On 2013-08-29 06:15:28 UTC - Size: 63.55 KB - 582 views
[2013-08-29 06:36:25]
Refer to paragraph 2.2 in this section here:
http://www.sierrachart.com/index.php?l=doc/LoginInstructions.php#LoginProblems
Most likely Internet Explorer is set to work off-line.
