Date/Time: Sat, 23 Nov 2024 23:53:08 +0000
User Email Questions - Cycle Tool
View Count: 1882
[2013-08-28 20:29:24] |
Sierra Chart - Max - Posts: 5730 |
The Cycle tool is not working properly, See link below, I have a 1 hour cycle and the next projected cycle is an hour an 4 minutes away Whats up with that? http://screencast.com/t/7s2AQ2ILPH The original cycle was drawn from 2:31 - 3:31 pm est however the next cycle ends on 4:35 pm Sierra Chart Support |
[2013-08-29 00:49:30] |
Al SC Developer - Posts: 434 |
This is working as designed. Each cycle is based on bar count. If you go across an area where there is no data (i.e. when market is closed), the times will get off. You can get around that by turning on Include Columns With No Data in Chart Settings >> Advanced Settings. This setting will insert bars where there is no data, and then your cycles times would match up. The time expansion/project tools have an option to be time or bar based. The cycle tool currently does not have this option and is bar based only. |
