Date/Time: Sat, 23 Nov 2024 23:57:53 +0000
Adding AD line indicator to existing chart
View Count: 3995
[2013-08-28 15:59:48] |
Demi1201 - Posts: 68 |
I can't add AD indicator to my existing SP500 chart. The indicator seems to require inputs that are not offered in the menu of inputs when I open such indicator in the chart itself. Any ideas? Does anybody use the AD indicator with their index? |
[2013-08-28 16:56:17] |
If you require the NYSE Adv Issues - Decl Issues, then follow the instructions here to use the Market Statistics data feed which is included with your package: http://www.sierrachart.com/index.php?l=doc/helpdetails66.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-28 16:56:50
[2013-08-28 22:52:01] |
OK, I've opened separate charts with these indexes: $NSHF: NYSE Adv Issues - Decl Issues (The number of stocks up minus the number of stocks down on the day.) $NVLF: NYSE Adv Volume - Decl Volume (The total volume of stocks up minus the total volume of stocks down on the day.) Can I display an indicator based on them under or over the SP500 chart? Can I watch in real time as I'm watching the 15' chart what's happening to the Adv-Dec sum? I'd like to see what kind of information that gives me. Thanks |
[2013-08-29 22:54:28] |
On those market statistics charts, you need to add the Advance Decline Line study. And then the result of that study can then be overlaid on any chart you want by using the Study/Price Overlay study: http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-29 22:54:53
