Date/Time: Sat, 23 Nov 2024 23:43:44 +0000
Using 2 doms same symbol
View Count: 1962
[2013-08-27 20:15:30] |
9baller - Posts: 38 |
Does SC support the use of 2 doms for the same symbol?... say I want to scalp around a core position...the core has is managed manually.... and the scalping is done through a autotrail or frog stop.... this way less confusing.... also any sound alerts when stops adjust....(ie Cash register)....evry thing adjusts silently |
[2013-08-28 00:40:26] |
Yes, open a new Trade DOM through File >> Find Symbol.
[2013-08-28 01:39:04] |
What i mean is use a second dom while NOT having the first position be visible in the second dom?....so that positions can be managed independently
[2013-08-28 05:19:03] |
This is not supported. However, there is the ability to use the Order fill calculated position in a chart or trade DOM and this is documented here: https://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#UsingIndependentInternalPositions So indirectly you might be able to accomplish this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
