Date/Time: Sat, 23 Nov 2024 22:02:09 +0000
set size for stock trade
View Count: 1434
[2013-08-26 20:25:18] |
richbatchelor - Posts: 15 |
i have tried many times to set size in the dom for astock to 100 shares. when iclick on the dom on the chart it always says 1 share. doesnt seem to belinked to the other dom.. what ami doing wrong?
[2013-08-27 00:49:11] |
On the Trade Window if you go to the Set tab you can set the quantities for the order quantity buttons. You can also set a default order quantity through Global Settings >> Symbol Settings for the stock. Here is the documentation for this: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php This Default Order Quantity is used when you click on the Quantity drop-down list box. All of the quantities there are in multiples of this quantity. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
