Date/Time: Sat, 23 Nov 2024 21:41:01 +0000
Trading multiple accounts using IQ data and accounts at IB or TDA
View Count: 1523
[2013-08-25 16:17:06] |
User23815 - Posts: 210 |
I am setting up the IQ data trial for futures trading at IB an/or TDA. For trading multiple accounts at IB, or accounts at IB and TDA simultaneously, is it possible to "one click" an order and have it transmit to accounts at both IB and TDA? Or would it require submitting separate orders for accounts at each place? If "One Click" is available for multiple accounts or dealers, then; within IB, I currently use the Advisor accounts. With SC is it possible to set up multiple copies of SC and "One Click" into multiple IB accounts, thereby bypassing the IB Advisor system, which seems more susceptible to problems? Thanks.
[2013-08-26 03:39:58] |
is it possible to "one click" an order and have it transmit to accounts at both IB and TDA? No.Or would it require submitting separate orders for accounts at each place? Yes.With SC is it possible to set up multiple copies of SC and "One Click" into multiple IB accounts, thereby bypassing the IB Advisor system, which seems more susceptible to problems? No.While you can certainly use multiple copies of Sierra Chart and each copy of Sierra Chart can handle multiple trading accounts per a trading service login, there is no way to do a one click trade into multiple accounts unless that is handled by the backend trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
