Date/Time: Sat, 23 Nov 2024 21:36:34 +0000
Something not right with the compiler
View Count: 2027
[2013-08-24 07:04:55]
maxpi - Posts: 181
I just built a machine, installed Win 7, SC [ver 1014, non-net] including the compiler. The compiler seems to be missing some libraries or something. A build of the skeleton study produces a lot of errors:
-- Starting build of Custom Studies Source File: TestThingy.cpp. -- 23:52:51
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\TestThingy.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\TestThingy.dll"
In file included from C:\SierraChart\ACS_Source\sierrachart.h:155:0,
from C:\SierraChart\ACS_Source\TestThingy.cpp:2:
C:\SierraChart\ACS_Source\scdatetime.h: In function 'SCDateTime GetCurrentDateTimeInGMT()':
C:\SierraChart\ACS_Source\scdatetime.h:1223:2: error: 'SYSTEMTIME' was not declared in this scope
C:\SierraChart\ACS_Source\scdatetime.h:1223:13: error: expected ';' before 'st'
C:\SierraChart\ACS_Source\scdatetime.h:1226:2: error: '::GetSystemTime' has not been declared
C:\SierraChart\ACS_Source\scdatetime.h:1226:19: error: 'st' was not declared in this scope
In file included from C:\SierraChart\ACS_Source\TestThingy.cpp:2:0:
C:\SierraChart\ACS_Source\sierrachart.h: At global scope:
C:\SierraChart\ACS_Source\sierrachart.h:182:45: warning: '__cdecl__' attribute only applies to function types [-Wattributes]
C:\SierraChart\ACS_Source\sierrachart.h:182:45: error: typedef 'fp_ACSGDIFunction' is initialized (use decltype instead)
C:\SierraChart\ACS_Source\sierrachart.h:182:45: error: 'HWND' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:182:64: error: 'HDC' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h: In static member function 'static char* SCString::StringNew(size_t)':
C:\SierraChart\ACS_Source\sierrachart.h:815:46: error: 'GetProcessHeap' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:815:53: error: 'SIZE_T' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:815:68: error: 'HeapAlloc' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h: In static member function 'static void SCString::StringDelete(char*)':
C:\SierraChart\ACS_Source\sierrachart.h:823:29: error: 'GetProcessHeap' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:823:41: error: 'HeapFree' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:882:3: error: 'COLORREF' does not name a type
C:\SierraChart\ACS_Source\sierrachart.h:909:3: error: 'COLORREF' does not name a type
C:\SierraChart\ACS_Source\sierrachart.h:922:3: error: 'COLORREF' does not name a type
C:\SierraChart\ACS_Source\sierrachart.h: In member function 'void s_UseTool::Clear()':
C:\SierraChart\ACS_Source\sierrachart.h:993:4: error: 'Color' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:1001:4: error: 'SecondaryColor' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:1009:5: error: 'LevelColor' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h: In member function 'long unsigned int s_SCInput_145::GetColor() const':
C:\SierraChart\ACS_Source\sierrachart.h:2485:48: error: 'RGB' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h: In member function 's_SCInput_145& s_SCInput_145::SetColor(unsigned char, unsigned char, unsigned char)':
C:\SierraChart\ACS_Source\sierrachart.h:2795:39: error: 'RGB' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h: In member function 's_SCInput_145& s_SCInput_145::SetString(const char*)':
C:\SierraChart\ACS_Source\sierrachart.h:2876:28: error: 'GetProcessHeap' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:2876:52: error: 'HeapFree' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:2888:55: error: 'GetProcessHeap' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:2888:90: error: 'HeapAlloc' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:2989:2: error: 'COLORREF' does not name a type
C:\SierraChart\ACS_Source\sierrachart.h: In constructor 's_NumericInformationGraphDrawTypeConfig::s_NumericInformationGraphDrawTypeConfig()':
C:\SierraChart\ACS_Source\sierrachart.h:3002:3: error: 'TextBackgroundColor' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:3002:25: error: 'RGB' was not declared in this scope
C:\SierraChart\ACS_Source\sierrachart.h:4521:2: error: 'COLORREF' does not name a type
C:\SierraChart\ACS_Source\sierrachart.h:4672:2: error: 'HWND' does not name a type
C:\SierraChart\ACS_Source\sierrachart.h:5704:66: error: 'COLORREF' has not been declared
C:\SierraChart\ACS_Source\sierrachart.h:5704:92: error: 'COLORREF' has not been declared
C:\SierraChart\ACS_Source\sierrachart.h:5756:2: error: 'fp_ACSGDIFunction' does not name a type
-- End of Build -- 23:52:52
Date Time Of Last Edit: 2013-08-24 07:06:27
[2013-08-24 07:10:14]
Please post a copy of your source code that you are compiling.
[2013-08-24 15:52:29]
maxpi - Posts: 181
// The top of every source code file must include this line
#include "sierrachart.h"
  For reference, please refer to the Advanced Custom Study Interface
  and Language documentation on the Sierra Chart website.
// This line is required. Change the text within the quote
// marks to what you want to name your group of custom studies.
SCDLLName("Custom Study DLL")
//This is the basic framework of a study function.
SCSFExport scsf_SkeletonFunction(SCStudyGraphRef sc)
  // Section 1 - Set the configuration variables and defaults
  if (sc.SetDefaults)
    sc.GraphName = "Skeleton Function";
    // During development set this flag to 1, so the DLL can be rebuilt without restarting Sierra Chart. When development is completed, set it to 0 to improve performance.
    sc.FreeDLL = 1;
    sc.AutoLoop = 1; //Auto looping is enabled.
    sc.Subgraph[0].Name = "Name";
    sc.Subgraph[0].DrawStyle = DRAWSTYLE_LINE;
    sc.Input[0].Name = "Float Input";
    sc.Input[0].SetFloat(0.0f);
    return;
  // Section 2 - Do data processing here
[2013-08-26 16:48:30]
maxpi - Posts: 181
I upgraded to 2015, no change in results. I'm compiling your code with your compiler in your programming/charting environment, can't see how I'm doing anything wrong at this end.
I'm learning about Windows licensing, the windows 7 I installed on this computer is not legal on this particular machine, I'm waiting on the new os disc to arrive. Perhaps that is affecting things?
[2013-08-26 18:17:06]
We did not see a problem with this but we are updating the compiler to see if we notice the problem.
[2013-08-27 00:19:55]
We cannot see why there is a problem still. Unable to duplicate.
Add this to the very top line of your source code file and recompile:
#undef WINVER
The other thing to try is to delete all of the header files in the /ACS_Source subfolder and then update Sierra Chart by selecting Help >> Download Prerelease.
[2013-08-27 02:28:17]
maxpi - Posts: 181
None of the suggestions have helped. I deleted the entire Sierrachart directory and scrubbed it's folder from the registry and reinstalled the program, still acting exactly the same.
I just upgraded the hdd to a ssd... that shouldn't affect things I'd think. I'd hate to go back to the disc drive but it might work then...
[2013-08-27 02:48:18]
maxpi - Posts: 181
OK, went back to the disc drive and everything works fine! The SSD is too fast for the compiler at some point? Who knows... Is it possible to use another compiler?
[2013-08-27 02:54:21]
This is very puzzling. We have a very fast development system with SSDs. We did not experience this. The SSD is not going to be too fast. That makes no sense.
You can use the Microsoft Visual C++ compiler:
http://www.sierrachart.com/index.php?l=doc/doc_VCExpress.php
