Date/Time: Sat, 23 Nov 2024 21:28:07 +0000
NYSE Tick data
View Count: 1518
[2013-08-23 08:49:25] |
User96105 - Posts: 113 |
Hi, I'm using the Sierra Chart Market Statistics Data Feed for NYSE Tick, which I find very useful. Is is possible to get NYSE Tick type data for the Globex session? Thanks |
[2013-08-23 09:06:20] |
What do you mean by "Globex session"? Do you mean the overnight session. If so, then the answer is no.
[2013-08-23 09:12:43] |
Okay, as I suspected, but thought it was worth asking...
