Date/Time: Sat, 23 Nov 2024 21:53:56 +0000
tpo market profile
View Count: 1443
[2013-08-23 08:19:15] |
michael baksheev - Posts: 27 |
Having problems changing time frame on tpo chart allows me to go to weekly and monthly chart times, no other. Have number of tpo profile peroide set to multiple peroids fixed by time . What am i doing wrong?
[2013-08-23 10:39:46] |
OK you first need to change the chart to an Intraday chart. Go to Chart >> Chart Settings and set the chart from a Historical Chart to Intraday Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-23 10:40:24
[2013-08-26 16:58:14] |
This is now performed automatically in version 1016 coming out today.
