Date/Time: Sat, 23 Nov 2024 23:28:02 +0000
TPO Profile
View Count: 2025
[2013-08-22 22:18:52] |
xRoads1 - Posts: 35 |
I have downloaded a trial copy of Sierra Chart. I am using the letters for TPO Profile, but the are smudged and unreadable. I have tried increasing spacing and font size so far. Additionally I don't know how to pull up futures symbols for my TDAmeritrade feed. |
[2013-08-22 22:24:09] |
User14266 - Posts: 225 |
You need to scale in to be able to read the letters. There are a few ways to do this: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html My preferred way of scaling in/out: http://www.sierrachart.com/index.php?l=doc/doc_Scaling.html#InteractiveScaling |
[2013-08-22 23:36:57] |
Provide a copy of the chart that you currently see where the letters are not readable, by following these steps: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Also, refer to this section here: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#Scaling TD Ameritrade currently does not provide futures data to outside programs like Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-23 02:05:05] |
Thank for the helpful responses, can you tell me which data vendors provide real time futures data?
[2013-08-23 10:59:39] |
Refer to this page: https://www.sierrachart.com/index.php?l=doc/data.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-30 04:07:52] |
Again you guys have been great and the package and TPO Profile is a great value for its price. The profile for a period indicates the open/close for the period. When you use the expansion function, "Letters/Blocks In Own Column", is there a way to show the open/close for each Letter/Block? |
