Date/Time: Sat, 23 Nov 2024 22:02:47 +0000
Historical P/L
View Count: 1588
[2013-08-22 14:07:43] |
User40229 - Posts: 10 |
Hello, I would like to have a history of my P/L on a daily basis. On the Trade Activity Log i have the P/L for each trade, but not the cum for each day. Is there some way to obtain this information ? Regards, CM |
[2013-08-22 18:02:43] |
Yes. Go to Trade >> Trade Activity Log >> Period Trade Stats. In the list box at the top select "Daily". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-08-22 23:13:58
[2013-08-22 20:05:49] |
Sawtooth - Posts: 4118 |
You can copy the Trade Activity Log into Excel each day and do your own trading history.
[2013-08-22 23:14:17] |
We need to make a correction. This is supported. Go to Trade >> Trade Activity Log >> Period Trade Stats. In the list box at the top select "Daily". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
