Date/Time: Sat, 23 Nov 2024 22:03:32 +0000
Zig zag source code
View Count: 2826
[2013-08-22 12:07:29] |
mario mario - Posts: 22 |
I downloaded the latest version today, and I dont see the source code, pl send me the link if it somewhere else thanks Old 03-14-2011, 07:43 PM SC_SupportGroup's Avatar SC_SupportGroup SC_SupportGroup is online now Sierra Chart Support - Engineering Level Join Date: Jan 2000 Posts: 60,542 Default Re: Zig zag source code The source code for the Sierra Chart Zig Zag study is provided. You can find it in the /ACS_Source folder in the folder where Sierra Chart is installed to. __________________ Cheers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. If possible please keep your questions brief and to the point. Please be aware of support policy. If your question/request has been answered and you do not have anything further, then it is easiest for us if you do not reply again to say thank you. |
[2013-08-23 05:01:28] |
The following files contain the Zigzag study code: /ACS_Source/studies7.cpp /ACS_Source/SCStudyFunctions.cpp Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
