Date/Time: Sat, 23 Nov 2024 21:53:06 +0000
How to move chart left to right?,
View Count: 1981
[2013-08-22 11:02:49]
DanielFitzpatrick - Posts: 12
Hi, I am wondering if there is a way to "seize " the chart and move it back, . Say, for instance I have a one minute up, and I want to see the one minute bar from an hour ago. I am wondering if there is a way to grab the chart and move it. I know how to shrink it, or expand it, but clicking on the bottom and moving left to right. The problem is this compresses it so much I can see the detail I want to. Thank you for your help. I hope I explained my question clearly
Dan Fitz
[2013-08-22 18:09:47]
There should be a scrollbar at the bottom of the chart. Make sure that Chart >> Show Scrollbar is enabled.
There may also not be enough data in the chart. To increase the amount of data refer to help topic 42.1 here:
http://www.sierrachart.com/index.php?l=doc/helpdetails42.html
[2013-08-22 23:14:28]
Sawtooth - Posts: 4118
You can also use the Hand tool
http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#Hand
