Date/Time: Sat, 23 Nov 2024 21:49:25 +0000
a 2ple of questions
View Count: 1609
[2013-08-22 10:19:59]
galk123 - Posts: 7
hi,
1. how do i get rid of the demand for confirmation each time i drag a stop or limit on the DOM scale.??
i would like to do one click drag&drop.
2.is it possible to add in the factor of an estimated broker's commission to the p\l calculator on the simulated trade
so a sim trader can have an immediate idea of the realistic profit due?? as close as can be to live..??
3. i could not find the "Hull -Moving Averege " in the study list , even though it is included in the studies detailed in your site.
can u help me get access to this MA??
thanks
[2013-08-23 02:59:52]
1. You need to disable the confirmations through the Trade Window and this is documented here:
https://www.sierrachart.com/index.php?l=doc/doc_TradeWindow.html#MenuButton
2. Commissions are supported through the Trade >> Trade Activity Log.
3. This is listed as Moving Average-Hull in the list of studies.
Date Time Of Last Edit: 2013-08-23 03:00:20
[2013-08-23 04:33:05]
galk123 - Posts: 7
thanks for the help spo far
still no good with #2-
could you be more detailed- how can i get a total P\L including commission.?
i can only check the "use commission" and "apply" , but nothing happens...
thaks
[2013-08-23 05:02:10]
2. Refer to the documentation here:
http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php
