Date/Time: Sat, 23 Nov 2024 22:00:58 +0000
s_SCTradeOrder does not indicate short or cover
View Count: 1646
[2013-08-21 23:03:29] |
hairyMug - Posts: 31 |
When using the GetOrderByOrderID , in an ACSIL function, there seems to be no way to see if it is a short position. Is there another way to determine if the curent position is a short position? Date Time Of Last Edit: 2013-08-22 21:57:24
[2013-08-23 02:44:19] |
You need to use this function: http://www.sierrachart.com/index.php?l=doc/doc_ACSILTrading.html#scGetPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-08-23 09:13:36] |
I have been using this function but s_SCPositionData structure has no obvious member to indicate what type of trade it is; long or short...
[2013-08-23 10:09:48] |
From documentation: [Type: integer] PositionQuantity The quantity of the current Trade Position as shown on Trade >> Trade Orders and Positions window. A positive quantity represents a Long position and a negative quantity represents a Short position. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
