Date/Time: Sat, 23 Nov 2024 20:43:57 +0000
buy side of trading dom fills at market when limit order placed
View Count: 1430
[2013-08-20 17:32:20]
Frontrunner - Posts: 20
hello support,
when an buy limit oco order is placed off the trading dom, the order is fill at market.
On the sell limit oco side of things trading dom works fine....fills at the limit price.
using sc ver 996
thank you
[2013-08-20 17:49:44]
When you say OCO are you referring to Attached Orders? In any case, it sounds like you need to ask your trading service about this. Unless you are using Sierra Chart Trade Simulation Mode. However, there should not be any problems with that.
Date Time Of Last Edit: 2013-08-20 17:50:15
[2013-08-20 22:16:32]
"When you say OCO are you referring to Attached Orders?"......yes
"Unless you are using Sierra Chart Trade Simulation Mode".....yes i am and have been, first time this problem has surfaced
like i said the sell limit works fine, the buy limit executes at a market order...
[2013-08-20 22:34:36]
If you are buying above the market, the fill price will be at the market. This makes sense.
Date Time Of Last Edit: 2013-08-20 22:34:51
