Date/Time: Sat, 23 Nov 2024 20:43:57 +0000
Referenced study data is zero on first pass
View Count: 1421
[2013-08-20 00:10:52]
onnb - Posts: 662
hi, I have the following setup:
1. 15 min chart has Numbers Bars Calculated Values applied to it (nbcv)
2. 15 min chart has my custom study applied to it
3. my custom study references the nbcv study mentioned above.
4. i have a 1 tick chart open and that is also referenced by my study
I am using AutoLoop = 1
I am grabbing the nbcv values using GetStudyArrayUsingID
What I am seeing is this:
when i first add the studies for the first time to the 15 min. chart, my study goes through a full calculation twice. The first time around, nbcv values I am retrieving are zero. On the second time around, I get the right values. Does this make sense and is this expected? If it does, is there a way to detect the first iteration?
Onn
[2013-08-20 00:34:17]
When you add the studies to the chart, does the chart reload itself? It would make sense that it will do that one time in order to calculate the necessary underlying volume at price data.
Also we recommend giving the chart that is using sc.GetStudyArrayUsingID a low precedence level.
Date Time Of Last Edit: 2013-08-20 00:34:27
