Date/Time: Sat, 23 Nov 2024 21:33:47 +0000
Error data feed Eurex
View Count: 1894
[2013-08-19 16:47:05]
Corefan - Posts: 13
Hello SC Support
I've experienced an issue with Eurex using Zen-Fire, v1012 non-CLR
Please see the attachment: as I can see the timestamps are the same
Thank you.
imageEurex.png / V - Attached On 2013-08-19 16:42:48 UTC - Size: 17.41 KB - 489 views
[2013-08-19 16:57:56]
We will solve this. We are using the exchange provided timestamp from the Zen-Fire system and apparently it is the same.
[2013-08-22 18:12:03]
Corefan - Posts: 13
Hello SC Support.
v1014 - situation has not changed.
Thank you.
[2013-08-23 01:52:59]
This is puzzling. If the problem is what we thought, it should have been resolved. Please give us one more day to look into this. We need to obtain a test account from Mirus.
[2013-08-26 17:10:43]
A time stamping issue with the EUREX and ICE futures has been found and has been resolved. This was causing incorrect timestamps in the chart and affected the building of chart bars. Update to version 1016 by selecting Help >> Download Current Version.
After the update is installed, follow the instructions in help topic 2.1.2 to re-download the chart data from before the timestamp errors in the affected charts:
http://www.sierrachart.com/index.php?l=doc/helpdetails2.html#h2.1.2
